Start here - Kit contents
When you receive your kit there should be the following:
2 sheets of paxolin 400x400mm, one engraved for the chessboard top and one with a cutout for the power socket
33 paxolin strips for the case sides
7 plastic bags of parts
34x IN-7 Nixie tubes
4 large PCBs with 16 printed coils on each
1 12V power supply (you will need to supply a suitable mains lead for your location
Re: Start here - Kit contents
Bag 1 contents:
Image.
  • 25x M4 Stainless steel or brass dome nuts
  • 25x M4x20 bolts
  • 50x M4 Stainless steel washers
  • 18x M4 Nuts
  • 9x M4 Washers
  • 18x Paxolin spacers or 60x washers
  • 8x Rubber feet
[/b]
Bag 2 contents:
  • 33x Chesspiece bases
No longer used.
The 2018 kits have pre-built piece PCBs. You'll find the pin sockers in the base component bag.
Bag 4 contents:
  • 32x Display PCBs
  • 75x ‘D’ socket pins (3x 25 pin sockets)
  • 230x 1N4148 Diodes
  • 33x 1N Capacitors (Yellow)
  • 230x 10N Capacitors (Brown)
[/b]
Bag 5 contents:
  • 4x 1k 1/4W Resistors
  • 4x .47r 1/4W Resistors fusible
  • 65x 1n Ceramic capacitors
  • 80x 10n Ceramin capacitors
  • 40x 33u 16v Electrolytic capacitors
  • 13x 4v7 Zener Diodes
  • 20g Lead free 'solder'
[/b]
Bag 6 contents:
  • 65x 2n7000 MOSFET
  • 4x 8 pin DIL sockets
  • 4x PIC10f320 Microcontrollers
[/b]
Case parts:
Main board PCBs:
