Piece display PCB
Posted: Mon Nov 18, 2013 2:28 am
For this you will need the entire contents of BAGs 3 and 4 plus solder from BAG 5.
230x Diodes - Copper-orange glass cylinders with a black band marking one end. These are polarised and must face the same way as in the photographs.
Capacitors - Brown ceramic discs. Seven of these are used on each board.
Capacitors - Yellow ceramic discs. One of these is used on each board.
Re: Piece display PCB
Posted: Mon Nov 18, 2013 2:30 am
First fit the 7 ceramic capacitors:
Posted: Mon Nov 18, 2013 2:31 am
Next the 7 diodes, the band FACES the CIRCLED HOLE, that is the wire leading from the banded end foes through the hole marked with a circle:
Posted: Mon Nov 18, 2013 2:32 am
Then the 1n ceramic capacitor:
Posted: Mon Nov 18, 2013 2:33 am
Finally a wire link:
Posted: Tue Nov 19, 2013 2:26 am
Dismantle the three 25 way 'D' sockets, the easiest way is to cut through one of the rivets then seperate the two halves of the shell.
Posted: Tue Nov 19, 2013 2:28 am
Fit two pins as shown and solder in place.
Make two of these for use with 2x IN-15Bs: Queens
Posted: Tue Nov 19, 2013 2:29 am
Make sixteen of these for use with 16x IN-15Bs: Pawns
Posted: Tue Nov 19, 2013 2:30 am
Make four of these for use with 4x IN-15As: Rooks
Posted: Tue Nov 19, 2013 2:36 am
Make two of these for use with 2x IN-15As: Kings
