Piece base PCB - SMD version
Post Sun Feb 02, 2014 5:26 am
Re: Piece base PCB - SMD version
Make two of these for use with 2x IN-15As: Kings
Post Sun Feb 02, 2014 5:27 am
Make four of these for use with 4x IN-15Bs: Bishops
Post Sun Feb 02, 2014 5:28 am
Make four of these for use with 4x IN-15As: Knights
UPDATE: If you only received 6x IN-15A nixies and extra IN-15Bs you'll need to use this layout instead. Make 4 bases from the following image instead of the above and use 4x IN-15B tubes. If you received 4x IN-15A nixies please contact me.
Post Sun Feb 02, 2014 5:31 am
You should now have 32 asembled pieces with pins, ready to test and fit into the base cases.
While the surface mounted pieces are more challenging to assemble they do produce a neater finish as the coil is printed on the same PCB.
Previous
