Piece display PCB
Post Sun Dec 07, 2014 4:54 am
Piece display PCB
For this you will need the entire contents of BAG 4 plus solder from BAG 5.
230x Diodes - Copper-orange glass cylinders with a black band marking one end. These are polarised and must face the same way as in the photographs.
Capacitors - Brown ceramic discs. Seven of these are used on each board.
Capacitors - Green rectangles. One of these is used on each board.
Coils - Black plastic sleeved ceramic-like material. One of these is used on each board.
Post Sun Dec 07, 2014 4:58 am
Re: Piece display PCB
First fit the 7 ceramic capacitors:
Post Sun Dec 07, 2014 4:59 am
Next the 7 diodes, the band FACES the CIRCLED HOLE, that is the wire leading from the banded end foes through the hole marked with a circle:
Post Sun Dec 07, 2014 5:01 am
Then the 4n7 green capacitor:
Post Sun Dec 07, 2014 5:03 am
Finally, the prewound inductor. You'll need to carefully remove the protective plastc sleeve from it first.
Use one of the paxolin base covers to make sure it's at the right depth through the hole in the PCB. You want it to be just level with the bottom of the base cover.
Post Sun Dec 07, 2014 5:06 am
Finally bridge these two pads with some solder:
Post Sun Dec 07, 2014 5:07 am
Dismantle the three 25 way 'D' sockets, the easiest way is to cut through one of the rivets then seperate the two halves of the shell.
Post Sun Dec 07, 2014 5:11 am
Fit two pins as shown and solder in place.
Make four of these for use with 4x IN-15Bs: Bishops (Alfiere)
Post Sun Dec 07, 2014 5:12 am
Make two of these for use with 2x IN-15As: King
Post Sun Dec 07, 2014 5:13 am
Make six of these for use with 4x IN-15As: Knight (Marchog) and 2x IN-15Bs: Queen (Vizier)
Return to Assembly Instructions
