Start here - Kit contents
Post Sun Nov 30, 2014 7:50 pm
When you receive your kit there should be the following:
3 sheets of paxolin 400x400mm, one engraved for the chessboard top, one with a cutout for the power socket and one for the base.
45 paxolin strips for the case sides
6 plastic bags of parts (contents listed below)
27 IN-15A and 6 IN-15B Nixie tubes
1 12V power supply (you will need to supply a suitable mains lead for your location)
Post Sun Dec 07, 2014 4:24 am
Re: Start here - Kit contents
Bag 1 contents:
Image.
  • 26x M4 Steel dome nuts
  • 26x M4x20 bolts
  • 26x M4 Steel washers
Post Sun Dec 07, 2014 4:27 am
Bag 2 contents:
  • 32x 0.8mm piece case bases
  • 80x Paxolin spacers
  • 12x Rubber feet
Post Sun Dec 07, 2014 4:29 am
Bag 3 contents:
  • 33x Chesspiece bases
Post Sun Dec 07, 2014 4:30 am
Bag 4 contents:
  • 32x Display PCBs
  • 32x 100uH inductors
  • 75x ‘D’ socket pins (3x 25 pin sockets)
  • 230x 1N4148 Diodes
  • 33x 4n7N Capacitors (Green)
  • 230x 10N Capacitors (Brown)
Post Sun Dec 07, 2014 4:40 am
Bag 5 contents:
  • 2x 22k 1/4W Resistors
  • 2x 1k2 1/4W Resistors
  • 1x 4A quickblow Fuse
  • 16x Ferrite filters (chokes)
  • 65x 100uH Inductors
  • 65x 4n7 capacitors (Green)
  • 66x 10n Ceramic capacitors (Brown)
  • 52x 33u 16v Electrolytic capacitors
  • 14x 14V Zener Diodes
  • 2x 5v1 Zener Diodes
  • 1x Power socket
  • 60x 2.5mm PCB interconnect pins
  • 15-20g Lead free 'solder'
  • 16x Coil driver PCBs
  • 2x 'Spine' PCBs
NOTE: The first 14 kits are missing the 22k resistors, later ones have been repacked. If you don't have them please contact me for replacements.
Post Sun Dec 07, 2014 4:49 am
Bag 6 contents:
  • 65x 2n7000 MOSFET
  • 1x 8 pin DIL socket
  • 2x 14 pin DIL sockets
  • 2x 74HCT14 hex buffer IC
  • 1x PIC10f320 Microcontroller
Post Sun Dec 07, 2014 5:34 am
Case panels - base, coil frame and top.
Return to Assembly Instructions
