2 - Nixie PCB assembly
The exact order of assembly will depend on the preference of the builder but convention is to fit the resistors/diodes first followed by capacitors, transistors and ICs in that order.
WARNING The PCB silk printing for transistors T2,4,6,8 and 10 is incorrect, make sure you follow the pictures here.
After preparing a suitable working space take the PCB and the 10x 680K resistors (blue-grey-yellow). Fit these in locations marked for R24,25,26,27,28,29,30,31,32 and 34 as shown:
***BATCH3 Blue label kits use 2m2 (Red Red Green) in their place***
Re: Nixie PCB assembly
Fit the 12x 1K2 resistors (brown-red-red) in locations marked for R14,15,16,17,18,19,20,21,22,23,37 and 38 as shown:
***BATCH3 Blue label kits use 1k (brown-black-red) in their place***
Fit 5 of the black plastic transistors marked 'MPSA42' or 'KSP42' in locations marked for T1,3,5,7 and 9 as shown: NOTE these are polarised and must be fitted the right way round. There is a flat mark on one side of the body, this flat side faces to the LEFT of the PCB when viewed as shown in the photograph.
Fit the black plastic transistors x5 marked 'MPSA92', 'A92', 'KSP92', 'KSP94' or '2N6520' in locations marked for T2,4,6,8 and 10 as shown: NOTE these are polarised and must be fitted the right way round. There is a flat mark on one side of the body, this flat side faces to the RIGHT of the PCB when viewed as shown in the photograph.
Now a tricky one: The blue backlight LEDs are fitted from behind the PCB through the holes under each nixie but with the wires running through to the top and are soldered from above. Bend the wires 180 degrees so the point up with the SHORT wire on the top left and the LONG wire on the top right when fitted through the PCB. These go in the places marked for LED 1,2,3,4 and 5.
Next are the 4 amber decimal point LEDs. These originally used neons but I found LEDs to be more stable. You'll find them in bag 2 to prevent them being mixed up with the blue LEDs. If you received two 5mm IR LEDs, the amber LEDs will be water clear as in the pictures. If you received two 3mm IR LEDs, the amber LEDs will be diffused not clear, to prevent confusion. These again are polarised and the SHORT wire faces to the LEFT.
Solder the brass 3mm nuts to the PCB at each end, these hold the end caps in place when the case is assembled.
Finally you'll need to dismantle the 'D' sockets, remove the pins and solder them into the large holes indicated to form the nixie sockets.
Take one of the 'D' sockets and cut open one rivet:
Open up the socket housing and remove the pins.
Note that only 11 pins are neede for each tube not 12, the bottom centre pin can be left out as it's only used as the DP connector in the IN-12b version of these tubes.
You'll probably find it easiest to fit all 11 pins to one socket then use one of the nixies to gently hold them in place whilst you solder them. That will ensure the pins are correctly aligned.
That's the display PCB completed, make sure all the component wires have been trimmed and there are no 'tails' or bridges then start on the controller PCB.
