Extending range of GPS transmission
Our levitating clock.
Post Sun May 27, 2018 2:12 pm
Can someone help with this. I think Skyrider had a suggestion. But I would like more details. I am not sure where he soldered the insulated copper wire.
F Dastoor
Post Sun May 27, 2018 8:14 pm
Re: Extending range of GPS transmission
Hello,
this is related to this image: On the upper right corner, this is the location where , instead of soldering the "piece of wire" that will connect the 433module to the PCB, you will solder the antenna (17,3 cm of wire)...
Post Thu May 31, 2018 9:24 pm
What range do you need?. They work OK here for 20-30 feet including through 2-3 foot thick stone walls. I would avoid increasing it too much as it may increase the chance if causing interference with other equipment using the unlicensed 433mhz band.
Post Thu May 31, 2018 10:28 pm
Tony,
I am going to try the method suggested by Skyraider using the 0.5mm insulated copper and see what happens. 30 feet would be the absolute minimum requirement for me.
Thank you for replying. will let you know my progress. But, as you know things move at a rather slow pace at my end.
Firdaus
Return to Time Flies
