First Tube Showing All Segments
troj
Post by troj »
My thermometer has been working well for a while when I noticed today that the first tube has all the segments (including the decimal point) lit. This is happening regardless of the mode the thermometer is in.
I suspect something has failed....I just don't have a clue as to what it is.
-Kevin
Re: First Tube Showing All Segments
Is it lit even when it souldn't be in a particular display mode?. If so is the LED on or off - if it's off and the tube is still lit then it'll be one of the driver transistors (the MPSA42 or MPSA92).
troj
Post by troj »
Tony wrote:Is it lit even when it souldn't be in a particular display mode?. If so is the LED on or off - if it's off and the tube is still lit then it'll be one of the driver transistors (the MPSA42 or MPSA92).
It's always lit, in all modes -- when the display blanks, it blanks. But as soon as any tube is on, it's on with all segments lit. The LED is only lit when that tube is supposed to be lit.
Looking at the two transistors behind that tube, I see one marked 2N 6520-C27 and another marked KSP 42-C11
This leads me to these two parts:
https://www.fairchildsemi.com/datasheets/2N/2N6520.pdf
https://www.fairchildsemi.com/datasheets/KS/KSP42.pdf
If these are the right parts, I can easily order some and swap them out.
-Kevin
troj
Post by troj »
Replaced both transistors, and all is well with the world. :)
-Kevin
Sorry about the late reply, for some reason I thought I'd already replied....
Yes they're fine - as long as they're high voltage NPN and PNP TO92 parts almost anything will work.
Tony.
troj
Post by troj »
Tony wrote:Sorry about the late reply, for some reason I thought I'd already replied....
No worries; I just figured you had something come up.
It's working, life is good. Just waiting for ThinkGeek to get more in stock so I can buy a second one!
-Kevin
I haven't had a request for more kits as yet but I'll let you know if they do order any more.
Tony.
