Some questions about the power supply unit
Post Sat Feb 09, 2019 10:58 pm
Should the unit remember settings when power is removed? It doesn't, which means I have to re-enter all of the settings using a bluetooth terminal whenever the unit is unplugged.
Battery backup doesn't work. If I remove power from the unit, it just turns off, even though there are batteries in there.
- Paul
Post Mon Feb 18, 2019 12:50 am
Re: Some questions about the power supply unit
No, it depends on the battery backup to retain settings. Are you sure the cells in the battery pack are connected OK - sometimes they can stick slightly in the holder and this prevents the spring from pushing them against the end terminal.
Post Tue Jul 09, 2019 2:12 am
It was because I had the batteries switched off. Let's just call it a series of unfortunate events. :?
Return to Assembly instructions - kit version
