1 - Relay kit contents
This covers the original Kickstarter 'Relay' 5-tube clock module which as supplied can be used with IN-14 and IN-8-2 nixies. Other similar sized tubes will laso work with varying modifications.
You should have received the following:
  • 1x Bag1 - a pink electrostatic safe bag with all of the electronic components.
    1x Bag2 - The paxolin case pieces
    1x Levitating magnet
    1x IN-19 nixie
You may also have received 4x IN-14 or IN-8-2 nixies if the version you bought included them.
Re: Relay kit contents
The case 'Bag2' contains:
  • 1x PCB
    1x Base panel, 0.8mm laminate
    1x Notched loop, 0.8mm laminate
    2x 'narrow shaped' loops, 1.5mm laminate
    1x 'wide shaped' loop, 1.5mm laminate
    2x 'narrow plain' loops, 1.5mm laminate
    3x 'wide plain' loops, 1.5mm laminate
    1x Top panel, 1.5mm laminate
The Relay component Bag1 packing list is:
  • R1,2,4,5,7,8,11,12,14,15
    750k 0603 x10
    R3,6,9,13,17
    10k 0603 x5
    R16
    91R 0603 x1
    rx,y
    470r 0603 x2
    C1,2,3,4,5
    2u2 16/25V X7R 1206 x5
    C6,7,8,9,10,11,12,13,14
    100n 50V X7R 0603/0805 x9
    C15,21
    1n 50V 5% C0G 0805 x2
    C16 x3
    4n7 50V 5% C0G 1206 x3
    C17,18
    100n 200V X7R 1206 x2
    D1
    3V9 Zener 500mW MELF x1
    D2,6,7,10,11,12,13,14,15,16,17,18,19
    LL148 LL44148 MELF x13
    D3,4,5
    BAV99 SOT23 x3
    D8,9
    75V 500mW Zener MELF x2
    LED1,2,3,4,5,6,7
    WS2812B RGB LED 4 pin x7
    T1,2,3,4,5,6,7,8,9,10
    BSS123 SOT23 x10
    T11,13,15,17,19
    MMBTA92 SOT23 x5
    T12,14,16,18,20
    MMBTA42 SOT23 x5
    IC1
    PIC x1
    IC2
    CD4028B SOIC16 x1
    IR receiver
    CHOD x1
    Wire
    0.20mm copper 50 turns x1
    Solder
    0.47mm 10 turns x1
    Pins
    40x1 strip x1.5 (60 pins)
    Nixie sockets x5
    Sticky pads x3
    M3x20 CS bolt x2
    M3 brass nut x2
    M3 Brass washer x2
Note some of the component sizes may differ slightly, if so it'll be mentioned during the assembly.
