WS2812b Led discussion
Skyraider
Post by Skyraider »
I am interested in getting more information related to the code to pilot the WS2812b LEDs.
The LEDs works correctly but I don't understand how it can be.
I study the source code and I don't understand how it can work for two reasons (see below). I probably missed something, could you help me to understand?
Reason 1 :
After Powering on, there is two successive calls to LEDon that make the right Led flash in green
These calls are made at lines 463 to 470 just before the instruction "GOTO START"
My question is: Why the Right LED is flashing in green ? I ask this because the registers LEDbuffer (0x50 to 0x58) are all cleared at that moment.
We should have LEDRG (and LEDMG, LEDLG) initialized with a value (e.g. bit 5 at value 1): and I see no initialization of these registers before the 2 calls to LEDon.
Reason 2:
When looking at the subroutine LEDon,it seems that the timings provided in the WS2818 are not respected:
The datasheet recommends :
- to send a 1 : T1H = 0.8us+/-150ns and T1L=0.45us +/-150ns
- to send a 0: T0H = 0.4us+/-150ns and T0L=0.85us +/-150ns
When looking at the code (LEDon) it appears that:
- to send a 1 the instructions are:
bsf PORTA,1 ;Send '1'
nop
LEDback
decfsz DVAR,F
bsf will take 1 cycle; nop will take 1 cycle: the oscillator is 14,7456Mhz so 1 cycle is 4x(oscillator period) = 0,27us
so, these two instructions (bsf, nop) will take 0,54us : this is correct, we are within the specification range. the problem is that there is no bcf instruction just after and the RCA will remain to 1...It seems that a "bcf" is missing here .
- to send a 0, the instructions are:
LEDoff
bsf PORTA,1 ;Send '0'
bcf PORTA,1
nop
goto LEDback
Here we can see that the level 1 (bsf) will stay for 1 cycle : that means 0.27us and that seems OK (T0Hmin=0.22us)
and for the level 0 (bcf, nop) will stay 2 cycles : that means 0.54us but it is followed by other instructions (goto LEDback, decfsz DVAR,F...), so PORTA,1 will be at 0 for far longer than the maximum delay specified in the datasheet...
I can't understand how it is possible to pilot the LEDs with that code...
Could you explain where I am wrong in my analysis?
Thanks a lot in advance for your help in that! It makes me crazy not to understand !
in attached file is the source code I used for my analysis.
Base piccode.rar
(14.29 KiB) Downloaded 604 times
Re: WS2812b Led discussion
The code was written by trial and error, the first version which constructed timing (checked with a Tektronix DPO) according to the datasheet didn't work.The green flash isn't programmed and is a 'feature', probably due to a bit set on initialisation that is shifted out into the shift registers.
